SealineTony
In past years with the coming of Winter and our boat being left in the water I have used a Powertxt device to remotely control a couple of tube heaters in the engine bay to pamper the little green VP demons. It works well allowing monitoring and control of heating remotely via SMS text commands. Usually set to automatic to switch on when the engine bay temp dropped to 5°c and off when the temp rose to above 5°c. It would also send automated message when mains power lost and again when switched on. For cabins like many I know I use a Meaco unit to control humidity.
The Powertxt device runs on a SIM and I used a PAYG one from ASDA as it was the cheapest at the time and would allow unlimited texts and was not linked to a monthly contract although it had to be used a certain amount of times in a 6 months period and would require, IIRC, only occasional top up to keep it active; result it cost peanuts to run over a period of 4 years. Sadly that account no longer around and of those I have seen so far most being a monthly commitment.
I am now looking around for a similar service and wonder if anyone has tried IoT SIM assuming a cheapskate individual could purchase one without entering into a yearly contract. On the face of it the solution appears to satisfy the need for data only at very low cost. However my assumption being that IoT SIMS being mainly linked to businesses.
Any thoughts or alternative suggestions gratefully received
I'm just a poor boy with a new motor boat
