Tim O
Hi....if I were looking out for a wind vane self steering unit for a 33 foot centre cockpit ketch with hydraulic wheel steering...what would you recommend, and why?
Cheers
Cheers
Cheers
Hydrovane, no lines back to the wheel works very well.
What sort of ballpark figure would one be looking at for a hydrovane? (The website gives nothing grade prices).
Minn has the price about right £4 to5K
Trust my boat to need the most expensive type !![]()
There is one possible snag with a Hydrovane if you are intending to use marinas a lot. The rudder is not easy to attach and detach and may make manoeuvres, particularly astern, difficult. With servo pendulum types usually the paddle can be swung out of the water but, of course, you have the hassle of steering lines. I had a hinge made up to allow the rudder of the Hydrovane to be swung up but it was a failure because waves breaking against the raised rudder distorted the gearing forks which I then had to have straightened. Depends on your type of sailing and how quickly you can launch and recover your Dinghy to attach or detach the rudder I suppose.
Just thinking...that a SP rope to wheel system might not work with hydraulic steering? if the system creeps at all, then it will gradually run out of correction room.
