windless remote control
emnick
30 Sep 2003
Essex
Hello, I was hoping to fit a new windless this season. Is there a wireless remote control on the market that anybody knows about? rather than fit switches. Also is there a DSC VHF with Navtex built in on the market that any one could recommend
Thanks in advance
rogerthebodger
3 Nov 2001
I use the same type of wireless remote control to operate my windlass as I use to open my driveway date. I just put it in a waterproof bag some as used for mobile phones.
If it stopes working I replace it they are very cheep in South Africa.
upto 6 way transmiter about 10 quid and receivers about the same for each channel. Can increase life by opening and spraying with WD40 or simular.
Gypsy
14 Feb 2004
Sydney and Australian East Coast
www.tech-x.com.au
Other posters have given you some good leads to products. I bought a Lofrans radio remote which hooked in with their control box very easily. It is not the same as the model shown in the link provided by Malthouse but I would expect it to be very similar. My unit uses the same technology as the garage door openers mentioned by RogerShaw but therein lies one of the problems of these type of controllers. The battery of the remote unit drains quite quickly, a matter of weeks if used when cruising. This is because it has to be held ON continuously to operate the windlass and this can be for periods of minutes whereas their original design use is for a momentary burst of the control data to start an open/close sequence. The manufacturers of my unit (badged Lofrans) obviously recognised this as a problem so they include a spare battery inside the waterproofed controller. The battery is 12v (from recollection) which is not too hard to find but not something available in supermarkets etc.
Whilst the portability and other benefits of these units are great, make sure you have an alternate control capability to operate the windlass if the controller battery fails at a most inappropriate time-which it surely will. I have a windlass control panel in the cockpit which is hard wired and used in such emergencies.
Ray
emnick
30 Sep 2003
Essex
Thanks Gypsy, I had also looked into garage / intruder alarm reciver transmitter but due to the problem you mention I presumed that the transmitter caused a relay to 'latch' on then there would be a 'stop' channel and then another channel for opposite direction. It could be done with a 3 or 4 channel Tx & Rx but the latching part would end up a bit of a lash up which is why I wanted a proper unit, one single burst signal to latch the relay up one single burst to stop one single burst for down.
Thank you all.
Gypsy
14 Feb 2004
www.tech-x.com.au
Yes emnick, latching circuits would be the preferred way of saving battery power but it has its safety problems. You really need the windlass to stop when you release the button. I think you will find all the radio units work on the same principle as the one I described, but I wait to be corrected.
Ray
