Sea Change
My windlass is intermittently, and increasingly, not working. Generally I hear a click from the relay box but nothing moves.
Occasionally it does burst in to life but it's slower than I would expect and can be stalled out easily.
It's wired to its own battery which charges using 50mm² cables from the engine. I'm getting around 14.2v at the windlass battery when the engine is running.
This morning I decided to troubleshoot with a multimeter whilst attempting to lift the anchor, and noticed that on the terminals of the relay box I was seeing the voltage fall to zero when I pressed the button.
I've done the obvious things- taken apart accessible connections and cleaned up, sprayed with contact cleaner, reassembled. I replaced the battery a few weeks ago. I try to let the engine run for a few minutes before using the windlass, to bring the voltage up.
Next steps? I have a spare relay box so I could try swapping those over. I could remake the crimped eyes on all the cables. I also have oodles of spare 50mm² cable so could swap out entire lengths.
All of the above involves wriggling in to a small, awkward, hot space. So I'd like to target the things that are most likely to actually work.
Based on the above symptoms, where should I start?
