Quandary
Southern Pacific horizontal windlass in a Moody S31. It is mounted by four bolts through a substantial GRP shelf across the back of the chain locker and getting it out is going to be a nightmare of contortion. About 10 years old but seldom used until last year.
Lat season it was working intermittently,I blamed the switch, not being able to get the plastic switch out intact I tore off the cables and after cleaning them up, by touching them got the thing to rotate forward and backward as expected. Fitted new Lofrans up down switch and cleaned or replaced up all the terminals on it and on the control box (solenoid).
Now when I operate the switch I get a loud click but no movement, there is about 13.5 v at the battery but the output cable terminals from the solenoid toward the windlass show around + or - 12.5 when the switch is held down. The gypsy is difficult to turn when it is at rest.
I presume that a windlass is just a reversible electric motor driving some gears so surely not much to go wrong. If it is getting 12 volts and under no load it should turn? The problem is that the whole top body is one alloy casting so the only access is through the bottom and the thing has to come right out to get the bottom plate off to examine it, this is going to involve much time and pain as the rear nuts can not be felt or seen in the narrow slot where the shelf meets the angled bulkhead, I am not good at working in awkward to reach spaces with my bum higher than my head. The manual on the website has an exploded diagram with part nos. but not much else. I was hoping it might be the solenoid which is cheap and easy to replace but it is outputting a current to the windlass.
So, if I get it out is there much hope that I can get it to go? I am hoping that it might just be another bad electrical connection but what else should I look at ?
Any suggestions gratefully considered including the one involving a skip.
