WindGuru
Wavey
26 Jun 2011
Home - Surrey
The WindGuru app doesn't work with ios11 and there's no upgrade in the app store. Pity as I found it quite a useful app to have on the phone.
Can anyone recommend an alternative?
Some usage tips for Windguru
These work for a registered user - not sure they are in the free version.
Also, this works for the new Windguru that came on line about a year ago.
I have set up lots of Favourite Spots that I then include into a number of Forecast Sets.
In each set, each Favourite Spot has a GFS forecast and a WRF forecast.
You can then click on the wind speed in either the GFS or WRF views to get the forecast map for that particular time and area.
Likewise, clicking on Pressure, Temp, Wind Direction and Cloud Cover etc - will take you to the appropriate Forecast Map.
On the PC, sometimes, you have to double click to get it to work.
Once in a Forecast Map you can maximise the window and pan/zoom around.
I have used Weather Track for a while and found it to be very good with pretty accurate forecasts consistently.
Several apps will work - see http://weather.mailasail.com/Franks-Weather/Grib-Files-Apps. Most use the US GFS. Most give alternatives. Given that the GFS uses a 12-13 km grid (although output is on a 25 km, 1/4 degree, grid) it really is as good as anything else. From my experience, there is no point in using anything else, despite claims of greater accuracy.
