wind instruments
jacs
30 May 2004
Has anybody any experience of NASA Clipper wind instruments? The rest of the kit onboard is Raymarine ST60 but I simply can't afford their version.
jerryat
20 Mar 2004
Nr Plymouth
Hi jacs,
I fitted one (Nasa) for a friend of mine in Spain and I'm sorry to say I thought it absolutely dreadful, with a poor quality display and cheap plasticy quality. He had trouble with the masthead transducer within a few months, though that may have been just bad luck with his particular unit.
I agree with Davidwf, I'd definitely try to get ST60 (or similar quality units) otherwise I believe you are going to be awfully disappointed.
Hope this helps.
Jerry
Samphire
23 Oct 2001
SW Ireland.
Don't touch the NASA wind with a 20ft bargepole.The quality of the masthead unit is worse than a childs lucky bag toy.It will be lucky to last a season before the cups disintigrate.The rest of the NASA range is cheap ,cheerful and ok.
Samphire.
Talbot
23 Aug 2003
Brighton, UK
you really need a wind instrument tthat can access the log speed, in orderr to get true wind speed and VMG (both very useful) thus as I suspect that most manufacturers equipment would not accept the output of anyone elses , you are probably stuck with that well known piece of equipment that loves the wet environment /forums/images/icons/smile.gif (i.e. raymarine)
DavidofMersea
18 Jun 2001
West Mersea in Summer - Ibiza in Winter
I have had the same experience with the masthead unit. The shaft the cups are fixed to has a flattened end which is moulded into the "works". Mine has become "unmoulded" after only a year, and the cups have dropped off. I propose to strick them back with superglue. Has anybody else had this problem? and if so, how did they fix it?
extravert
20 Jun 2001
Not far from Uwchmynydd, near Bwlchtocyn, just up
My previous boat had a Nasa wind instrument. After 9 months from new a cup disappeared from the transducer. Nasa would not admit that there was anything wrong with it and would not honour the guarantee. The new set of cups I was forced to buy was the last item that I will ever buy from them. Cheap, but not worth it.
My 4 year old ST60 system has not required any repairs yet.
<hr width=100% size=1>One day, I want to be a real sailor. In the mean time I'll just keep tri-ing.
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
My shaft was snapped off (ouch!)
I got a new one from NASA (free of charge), drilled a hole right through and araldited the new shaft in place.
No-one was more surprised than me when I put the mast back up and it worked!
- Nick
<hr width=100% size=1><font size=1><A target="_blank" HREF=http://www.bluemoment.com>http://www.bluemoment.com</A></font size=1>
DavidofMersea
18 Jun 2001
I followed your example and superglued mine. Mine is on the roof of my house. I put rubber bands round it to hold it still, whilst the glue set. Now I have got to wait until the rubber bands perish - then I can tell you if superglue works
