Wind Force 4/5, long fetch, one full sail or 2 reefed?
John - Ease of setting the sails is important to a husband and wife (nervous) crew, This is my second year with in mast furling, I whilst I get very upset about the crap pointing to windward, partly induced by baggy 140% Genoa, I have had some really heavy sailing this year; the reefing was just so easy and was done in complete safety of the cockpit.
In mentioning my baggy genoa - I asked my tame sail maker what he thought of the sail - he said the material was too light for extended cruising, and needed to be at least 2 cloth weights heavier. He has suggested that for the Med I need a 110% genoa in much heavier cloth, the logic being that it either blows of you motor in the med. With a 140% genoa you will always be sailing to windward with a rolled up bag, compromising the inmast furling even more. He also suggested a cross cut in stead of the bi radial cut I have at the moment.
As you have a similar boat, what do think of this advice? We are off to the Med on May 1st 2009.................... Can't wait!
Chris
[/ QUOTE ]I think his advice makes sense. My last discussions with my sailmaker convinced me that I probably need TWO genoas. A lightweight reaching genoa and a heavier weight beating and reaching genoa.
No where did I put my piggy bank...?
I think it makes sense too and glad of another opinion. Where there is a string likelihood of a long down wind passage - eg down coast of Portugal, then bend on large genoa. Otherwise fit small 110% genoa.
Can't find my piggy bank, but have a list as ling as my arm of bits to do before setting off south.
Holding Tank
New fridge - Westerly job has B all insulation as is too big - any ideas?
Water maker - do I need one? (Eastern Med)
Solar Pannels
Double battery bank size
Bimini
Fans
Large sun awning
Gelshield Hull
On and on.........
[/ QUOTE ] Simplest solution would surely be to add new insulation inside existing fridge??
- W
Holding Tank
Solar Pannels
Bimini
Fans
Large sun awning
Gelshield Hull
On and on.........
No need for water maker in the eastern Med. Call in to a marina or visit town quay - the latter will either have tap or visiting water (or diesel) tanker
Many thanks John and others for this useful advice. In fact we fitted a new fully battened main and stackpack this year - after advice from forumites some months ago. Very pleased with it and we usually manage to avoid snagging the battens on the lazy jacks
Holding Tank
Solar Pannels
Bimini
Fans
Large sun awning
Gelshield Hull
On and on.........
Thats what I wanted to know!!!! thats £3000 off the bill... Thanks
- W
I thought about doing this. The problem is making it waterproof. I can imagine the smell a few days after spilling milk! The compressor needs replacing as it is not man enough for the uk let alone the med.
I will start again - make a stainless liner, new water cooled compressor from Penguin - and all for what - COLD BEERS!!!!
