dylanwinter
one of the things about the Minstrel is that not only does it have an outboard in a well but it is designed to work with a short shaft engine that does not actually stick out the bottom of the boat.
This miracle of design is achieved by a sort of prop sized tunnel thing that stretches right back to where the centre plate drops out of the bottom of the hull
the idea is that this tunnel thingy not only helps to keep the hull rigid but means that the engine prop is running in a sort of duct
I have never seen this done before and had no idea the boat had such a thing until I looked under the boat
I understand that most owners find that a long shft sticking clear of the bottom the boat into clear flow works better but is slightly more vulnerable. That also allows you to vector the engine. Vectoring a short shaft in the tunnel will achieve very little
I put a defunct two hp honda into position to see what it looks like
I assume it will just agitate a load of water and kick it white out the back of the boat
but I might be wrong
I can not wait to find out
will this ever work?
I hope I have explained what it looks like
I did make a short film
it is on a page on a website
no link
Dylan
no link
Dylan
