will this actually work
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
one of the things about the Minstrel is that not only does it have an outboard in a well but it is designed to work with a short shaft engine that does not actually stick out the bottom of the boat.
This miracle of design is achieved by a sort of prop sized tunnel thing that stretches right back to where the centre plate drops out of the bottom of the hull
the idea is that this tunnel thingy not only helps to keep the hull rigid but means that the engine prop is running in a sort of duct
I have never seen this done before and had no idea the boat had such a thing until I looked under the boat
I understand that most owners find that a long shft sticking clear of the bottom the boat into clear flow works better but is slightly more vulnerable. That also allows you to vector the engine. Vectoring a short shaft in the tunnel will achieve very little
I put a defunct two hp honda into position to see what it looks like
I assume it will just agitate a load of water and kick it white out the back of the boat
but I might be wrong
I can not wait to find out
will this ever work?
I hope I have explained what it looks like
I did make a short film
it is on a page on a website
no link
Dylan
I expect the motor boat boys will know better than us.
I think 'tunnels' is the term used for power boats that have this. The boats can be used in much less depth than normal and are protected when taking the ground.
I would think that this option would work very well for your type of sailing with, perhaps, a small loss in performance.
cripes
you mean I have bought a Mobo
I shall have to start muttering dark things about myself as I go past
that is the one
Hi Dylan have a look at the photo link to a Watson life boat prop tunnel
http://www.nelsonsboats.co.uk/boatphotos/88/E653B6BD-2C2B-4B79-BFA4E8837F624273.jpg
very much like that
thanks for posting the image
only just the one tunnel on Katie
maybe it will work
the good thing is that it keeps the prop out of the way of the lobster pots that have done for me three times so far this journey
in the film you can see that jonly the very tip of the outboard skeg sticks out beneath the bottom of the boat
getting more optimistic now
Dylan
no link
Dylan
One ton per HP is the going rate i think i read :)
is it a bit like this one?
You said it yourself, the stern looks like a lifeboat. All the RNLI's beach-launched boats have the props in tunnels, I believe (except the newest one which I think is jet-drive) and if it's good enough for them...
provided the water squirted OUT by the prop does not exceed the ability of the tunnel to coax water IN, then all should be well (geddit ?).
PS. So really you have bought a mobo catamaran ?
I fear
I fear I have bought just that
some indication of the success, or otherwise, of the tunnel is that I beleive that most Minstrel and Liberty owners use long shaft outboards
and if tunnels were all that brilliant then you would see more of them
however, we shall see
I do know that the previous owner tried his 2hp mariner on it and said it was fine - but the engine has no reverse
the honda can turn around in the tunnel so I may have reverse
Dylan
this was the man
Was that the Gunn behind Gunn and Moore cricket bats?
In which case, rather than Katie Hell, you could call her 'Willow'.
I admire the eccentricity of the name choice it does seem a bit weird
http://en.wikipedia.org/wiki/George_Gunn
I do know that I would get really bored with sansering the same question asgain and again
all posed by Cricket fans
Cricket enthusiasts are nice enough blokes of course - nothing against them at all
quiet, unnasuming sorts in my experience.
If it is to be named after a man then I think it should be a sailor rather than a circketer
How about "Ted Heath"
- he was always one of my heros
I can remember at the time thinking - he is a sailor - must be a nice bloke
Dylan
can't
Nice looking boat Dylan but get it in the water where it belongs.
I have got the Humber and the Tyne to do
7 knot tides
- so I would rather be in a boat I know and one that can take a few knocks and scrapes as I intend taking it a fair way inland along some of those big freight routes
there will be a lot of bottom bashing and lock crashing
The gunter rig has not been used for 15 years so it needs a bit of fettling
I have no four stroke outboard - part from the tiny Honda
no cooker
no reliable electrical supply
no sink
no lights
the boat as been primarily used for day sailing in and around Poole Harbour
So I have no idea when the boats will be swapping over
not that soon is all I can say
The slug is for sale..... £1500 and it is yours ... which should just about cover the costs of a new outboard and an origo
so I shall carry on sailing the slug until some-one buys it
no pressure
Dylan
Bargain! I don't think my mrs would be too happy if I bought the slug, I already have 2 boats - sailing dinghy at home and old river mobo in marina. I enjoyed the day out on the slug though.
