Elessar
Thank you. It’s consistency to stream rather than ultimate speed I want.One thing you should bear in mind - this will be slower than your phone. It's LTE Category 4 which is quite old, but it will maintain a stronger connection more of the time so should be much more consistent than a phone (which are now category 14 or more!).
Radar arch will be a good spot, but make sure it's not level with the actual radar - I don't know if it'd cause damage but I can't imagine having them level would be good when the radar is on. I suspect that for mounting you might get away with raising it a couple of cm using a GPS Antenna mount or something similar, which could be glued down easily enough. Do a dry run before mounting so you can test wifi around the boat. If the radar arch is metal it might block a signal, and water and fuel tanks, engines, etc. might also block signals. Easy on a single floor yacht but your boat may have a more complex layout, although I'm guessing most things like that will be low down.
Arch and everything high is GRP and all significant metal things are under the saloon floor or aft cabin bed.
Agreed 100% on height diversity with the radar. Will arrange that.
Ive ordered it. Will try it with my 3 SIM and load some data onto my EE sim and compare results.
I don’t need a bosun’s chair to change the sim!
