KellysEye
>http://www.astrocalc.com/
Make sure it is 12db, we used a stand alone one on a base but i can't remember the make.
Mistroma or GHA (or anyone else who knows...). Would it be at all possible to post some instructions and recommended kit to set up the antenna/Rasp pi solution? I can be as technical as I need to be, but am certainly not familiar with the right combination of antenna and I've only used a pi once.
Any advice v gratefully received.
Many thanks!
No rush at all. Happy to wait for instructions!Stock was short when I ordered but I managed to get a Pi Zero W a couple of days ago. I managed to lose my only mini-HDMI adapter (probably in Sardinia) and am still waiting for one from eBay.
I did try a headless install (i.e. No monitor) of Openplotter but had problems getting any response from the Pi Zero W. I installed Raspian instead meantime and edited files on the SD card to enable connection to my home Wifi. I have it running now with a few add-ons but haven't had time to install bits needed to make an Access Point.
Now falling behind in list of things to do before leaving UK in 3 weeks for summer on board. I'll document my progress if I get time but it will be on hold for a week or so.
Perhaps GHA might be able to help more quickly as I think that he has already setup a Pi3 for this task.
The PoE route also frees you from incompatible drivers but you do need a spare ethernet port configured as a WAN. Examples of PoE WiFi antennae are the Tube 2H or Ubiquiti Bullet.
I looked at the Bullet. It seems to need a mains power supply. Is that correct? (Sorry, but the only pies I understand are the ones that come in tins)
The spec says up to 24v DC, mine runs happily on the boats 11-15v supplied through something like this, http://www.solwise.co.uk/wireless-poe-injector-epe1212.htm. There are quite a few PoE injectors that come with a mains power supply. If you wanted to be sure you have a DC plug that will fit the injector buy one of those and cut the DC wire as it comes out of the mains box and rewire for a cigarette lighter plug (or however you want to power it).
...I managed to find a document giving all the information I needed to setup my Raspberry Pi Zero W as a wireless access point. The Pi Zero W is still very new so there are a few changes.
Curiosity question; how do you access your Alfa WiFi antenna to set it up for the service youre trying to share ? In outline I understand what the setup youve described does, what I cant see is how you get it to connect to the remote service.
You can then connect using VNC Viewer to see the Raspian desktop on laptop (or tablet). Just a matter of pulling down the Wifi icon at the top, selecting the required Access Point for wlan1 and filling in the password. This will then give access to the internet for any devices connected to wlan0 AP.
Raspian will remember the password and try to connect to the selected external AP each time the Pi restarts.
When I started to read this post I was hoping to find out if I could just buy an aerial to plug into my IPAD to get better reception.
The gobbldegook that follows just shows me that i have absolutely no hope & that whatever i do i am not going to get a decent WIFI connection in most marinas that I go in.
So just getting a weather report will be a lottery at best
Such is life !!!!
I don't think that I am particularly stupid but this is the conclusion that I have come to as well... Still the upside is that I will HAVE TO go to bars along the way.
... I'm guessing that the best option for less techie types might be to use a SIM instead of spending cash on Wireless kit.
Apologies, finally got round to checking this works on a Pi zero this morning, took maybe half an hour?Mistroma or GHA (or anyone else who knows...). Would it be at all possible to post some instructions and recommended kit to set up the antenna/Rasp pi solution? I can be as technical as I need to be, but am certainly not familiar with the right combination of antenna and I've only used a pi once.
Many thanks!
Seems pretty stable, I'm actually surprised the Zero has enough power out of the microUSB to power both dongles - a powered hub would be a wise addition for a real world solution.
- Download openplotter v0.8.0 from here -> http://www.sailoog.com/en/blog/download-openplotter-rpi-v080
- On windows, use this program to burn the image onto a SD card -> https://sourceforge.net/projects/win32diskimager/
More details here -> https://www.raspberrypi.org/documentation/installation/installing-images/windows.md- Now the SD card should be written, in a file explorer edit the file config.txt in /boot/ so it looks like this.. ->
[OPENPLOTTER]
#HEADLESS
# uncomment to force screen resolution (only VNC remote desktop)
framebuffer_width=1000
framebuffer_height=800
# uncomment to set WiFi access point. wlan0, wlan1, wlan2 ... default=wlan0
device=wlan0
# uncomment to set WiFi access point. SSID must have a maximum of 32 characters, default=OpenPlotter
ssid=OpenPlotterZero
# uncomment to set WiFi access point. Password must have a minimum of 8 characters, default=12345678
pass=12345678
# uncomment to set WiFi access point. b=IEEE 802.11b, g=IEEE 802.11g, defaul=g
hw_mode=g
# uncomment to set WiFi access point. 1 to 11, default=6
channel=6
# uncomment to set WiFi access point. 1=WPA, 2=WPA2, 3=both, default=2
wpa=2
# uncomment to select device connected to Internet and share connection. wlan0, wlan1, wlan2 ... default=0
#share=0
_____________________________
- Install a vnc viewer on your laptop - I use one in chrome -> https://chrome.google.com/webstore/search/vnc%20viewer?hl=en
- Power up the Pi zero and wait a moment for it to boot up - there should now be a wifi access point called OpenPlotterZero (or whatever you called it in the config.txt file) . Connect laptop to this.
- Open VNC viewer and connect to 10.10.10.1
The Pi screen should now be visable.- Attach 2nd wifi dongle, top right of the scree just to the left of the bluetooth icon, press the icon which looks like a lead plugged into a wall - this should let you log onto any available networks - log onto your favourite.
- Now edit the config.txt file again, change
#share=0
to ->
share=wlan1
(Note - you can do this with the SD card in the Pi, in a terminal just type ->
sudo leafpad /boot/config.txt
This means... "sudo", like administrator in windows, "leafpad" a text editor already loaded onto the Pi so basically means "Open the file config.txt in /boot/ and let me edit it as I'm a grownup.)- Now, reboot and log onto the openplotterzero network again, if all is well then the Pi is acting as a wifi hotspot rebroadcasting the othe wifi network.
This was done on a Pi Zero (no inbuilt wifi) , a nano wifi dongle and a TP link wn722N both plugged into a usb hub into the Pi Zero microUSB socket.
