NDG
We are having some work done at the moment and I want to replace the highfield lever on the removable inner forestay with an adjustable Wichard fitting. I have used the highfield lever a lot and I find it difficult to fit in rising conditions and quite hard to get enough tension on it.
The forestay itself is 5mm. The rigger thinks that the Wichard 5554, which has an 8mm thread, might not be up to the job and he is wondering if we should fit the next size up, a 5556, with a 12mm thread. This would mean upgrading the inner forestay from 5mm to 6mm. I think the concern relates to the tendency of the fitting to bend to lateral forces when tacking/flogging rather than the strength per se.
the boat is 32ft (Contessa) and we use the inner forestay to carry a number 3, with the genoa rolled away, not just for storm sails, so it's used a lot.
I know this is a very specific question but does anyone else have a similar fitting who can give an opinion on what size would be most appropriate?
