rustybarge
Just a small caveat about using wi fi hotspots for private data........http://www.bbc.com/news/technology-26469598
Hi Paul,
I would appreciate your comments on this: http://www.metisair.co.uk/products.asp.
Seems a compromising bit of kit price viz efficiency.
I would have thought it worth getting something with a higher gain antenna whilst you are at it. That kit supplies with 8dB but it's possible to do better than that IMHO. I've done a "home brew" set up and used a 15dB simply as the more the merrier to some extent AFAIK.
HTH
Paul
Yes, I have been told the métis does it automatically. That is an advantage I guess.
Hi - Marie from MetisAir here.
Paul, we considered offering such a high gain antenna but elected not too. Have a look at our FAQ page where the rationale for this is addressed:
http://www.metisair.co.uk/faqs.asp
Powersalt, what you have been told is correct. MetisAir remembers all of the remote hotspots you connect to and then automatically reconnects as you move location.
Hope this helps
Marie
HI, I have just come back from a week in sunnier climates and have picked up on this thread again.
You mention the aerial and say you consider higher gain but you do not sat why you do not copy the likes of Digital?
ALso I have a second question, ref the cable does it have to have the ends fitted and as such the need for bigger drilled holes? just a thought
It looks more complicated than it is!![]()
