pugwash
In one of the posts about winterizing there was a query about whether or not to remove the raw-water pump impeller. I've just come across winterizing advice from a US outfit called Boatdiesel which says: "Filling the raw-water circuit with anti-freeze will swell the pump impeller and render it useless. Remove the impeller if you use anti-freeze."
Is this right? I don't remember seeing it discussed.
