Mataji
On a sailing boat with space for 2 batteries, why not have 2 leisure batteries rather than 1 leisure battery and 1 dedicated starter battery?
I know the current thinking is to have dedicated starter and leisure batteries, but I have two 110ah leisure batteries controlled by an (old fashioned) 1 both 2 switch, so you can choose whichever for engine starting/leisure and combine the two if one goes flat. In practice I use them alternatively and have rarely had to use both. I'm a fan of the KISS principle.
We have a customer on the river with an old hand crank Bukh, he just has an old car battery on board for his lights and a few odd things. Now that is keep it simple!
Some knowledgeable people advocate not having a dedicated starting battery, but instead installing one of these:
https://www.batterybrain.co.uk/about/
But.... "do NOT combine the two if one goes flat, due to a dead cell. That just pulls the good one down to 'unusable'. Instead, isolate the dead one, then switch to the good one, use that to start the engine, etc, then go home and investigate/resolve the problem.":
Absolutely. Never parallel a dud battery with a good one.
Not sure that is KISS, you've bought 2 batteries but are effectively only using one.
Yes, but I can still reserve one battery for starting but use it as a leisure battery if necessary. If I use a starter battery as a leisure battery it would soon be ruined.
I'll get my popcorn this is almost as good as an anchor tread.Not sure that is KISS, you've bought 2 batteries but are effectively only using one.
