Lon nan Gruagach
So why would any one of us "require" an aluminium alloy anchor?
Those with aluminium boats are quite keen on them...
That would be my guess too. Entering "Light Alloy" into wikipedia redirects you to "Aluminium Alloy" but does not further mention the term. My impression is that "light alloy" was the common name for aluminium alloys (in Britain at least) in the 1940s and 50s, but I have been unable to find a history of that usage.A contraction of the old "light alloy", I suspect.
luminium and stainless steel together also appears to be a bi-metallic corrosion risk, from the 'nobility' table.
With this combination the affect of relative surface area on corrosion is important.
A large area of 'cathode' relative to 'anode' will accelerate the anodic corrosion. Although aluminium is anodic to stainless steel, large relative surface areas of aluminium to stainless steel can be acceptable, dependant on local conditions.
To complete the cell, a conductive liquid must bridge the contact metals.
The more electrically conductive the liquid is, the greater the danger of corrosion. Seawater or salt laden moist air is more of a risk than contact with rain water or towns water.
In testing I agree that Aluminium and Stainless steel would be ok , but we are dealing with Salt water , and salinity in Water varies around the world ,The deep salinity within the Mediterranean Sea is between 38 and 39 psu and in the North sea The salinity averages between 34 to 35, so does the composition of the water with other chemicals present, Just saying
People like to test in nice dry environments wit hall the best tech .
Whilst it is indeed possible to get 7000 series alloys with similar tensile strengths to steel, there is a crucial difference: they are brittle.
In rocky holding, a steel anchor may possibly get a bent shaft ... try bending a piece of forged steel, you'll be able to bend it into a U shape with enough force, no cracking.
Bend a piece of thick plate 7082 and .. you'll have two pieces ... it simply is not malleable. It cracks and fails.
I'll stick with tried and tested heavy steel anchors, ta very much though.
Whilst it is indeed possible to get 7000 series alloys with similar tensile strengths to steel, there is a crucial difference: they are brittle....
I wasn't so much thinking of ham-fisted recovery, but when it gets caught up in a rock in a bit of a blow, and you end up side-loading the shaft ... the steel anchor will just bend and hold ... the alloy one, well, I suspect it may bend and fracture ... not hat you want at 3am in a big sea ...
Can an aluminum anchor dig as well, in all bottoms? That is the question. We know some do very, very well in certain bottoms. We know Fortress is not good in some bottoms, but not because it is aluminum. I'd love to hear about aluminum Spade and other anchors. I think there are also more interesting things to be done with high strength steel that we have not seen yet.
............ only NormanS admits to have owned a genuine Danforth and Fortress and when last heard was trying to offload the Danforth.
I've had several genuine Danforths, and I've also chosen to carry a Fortress on all my latest boats.
Great stuff, real experience.
Did you notice any difference in the performance of these similar anchors? Thanks.
One thing about the market is that only half of it is sailing boats. The other half, motor boats, can sometimes benefit from extra weight on the nose. But the main reason I’ve never considered an alloy anchor is that I’ve never seen one! But the real question I want to ask is what type of rode goes with an aluminium anchor?Why would you carry any extra weight - if it was unnecessary, especially in the bow.
Jonathan
Without like for like testing (a bit like YM do every few years), in identical conditions, with measuring equipment, it's not really possible to give any really valid conclusion....
Weight in the ends can have a theoretical effect on a sailing boat. So 7.5 kg in the bow balanced with similar weight in stern would not change the COG, but in theory it could effect the performance, but only to a tiny degree in some conditions.I'm puzzled by this "weight in the nose" business. A Bavaria Cruiser 34 weighs 5.3 tonnes empty, so about 6 tonnes in cruising trim. Spade#s "Anchor Selector Wizard" recommends either a 15kg S80- or a 7.5kg A80 (note to sceptics, yes, they recommend aluminium for the main anchor) for that size. Going for steel instead of aluminium will shift the centre of gravity forward by (7kg x 5m) / (6,000kg) = just under 6mm. How terrible is that?
