Neeves
So ideally the primary and kedge anchors would be very different models. A Mantus, Rocna or steel Spade are typical premium primary anchors (although there are many other choices), and an aluminium Fortress or Guardian is used as kedge. The biggest dilemma concerns what happens if the primary anchor is lost. In an ideal world a spare primary anchor would be carried, but some boats accept, I think often reasonably, that the kedge anchor can be used with caution as a primary anchor until a replacement primary can be found. Much depends on the remoteness of the cruising grounds, time away from marinas, and the practicalities of retrieving a stuck primary anchor.
So still in denial
Please provide any information you have on the hold of Mantus.
Your credibility looks questionable yet you still want to attack an anchor you have never used, aluminium Spade yet continue to champion Mantus that you have used that has no performance data you can quote. It obviously has a defect - that low fluke seabed angle - yet you are unable to even attempt, in the face of evidence from, amongst others, the US Navy - that a low angle produces a low hold.
Mantus has the hold of a similarly weighted Delta and should not and cannot merit comparing, favourably, with a Rocna or, even, and aluminium Spade.
I have used all of these anchors and tested all of them.
By modification of Mantus it can be made as good as a Rocna - which is what Viking has done - but as is - its not worth the hype
Jonathan
