Benbow
It is always being said that harness lines should be double-ended so that you can release yourself if trapped. I seriously wonder if there are ever circumstances when you would be better to do this than to stay attached to the boat. A while ago there was the tale of a delivery boat in Biscay, rolled by a breaking wave and 2 went overboard. They released their harnesses because they were ‘trapped’, one died and the other survived only because they were very close to land. A man who remained on the boat was relatively unscathed. It seems to me that you are almost always better to stay attached to the boat even if you are being held underwater – a conventional boat is highly likely to right itself, but if you detach yourself you are highly unlikely to survive. After all, following a roll what are the chances of a remaining crew organising themselves to conduct an MOB recovery before you vanish ?
I wonder if this idea being drilled into our minds that we should always be ready to cut ourselves free from the boat is in fact extremely bad advice.
Any thoughts?
Any thoughts?
