colhel
I know we them and boats fall apart without them, but, why will my bits fall off without them? And how does an anode stop it?
Quote:
Fe → Fe2+ + 2e-
(1)
O2 + 2H2O + 4e- → 4OH-
(2)
2H2O + 2e- → H2 + 2OH-
End Quote
Thanks. That explains it!![]()
'cos, like everything there is always a trade off. Many boats hardly use anodes at all. My old wooden boat the anode lasts for at least 5 years. In the Med, my saildrive anode was still sound after 8 years. Some GRP boats have no anodes at all and have no problems. Yet others are in situations where there are lots of stray currents and anodes last only a short time. In yet other boats the mix of metals is such that there is a greater possibility of galvanic action. So, you plan your anode strategy to suit your particular boat and location.Why don't they use bigger or more anodes to save the boat coming out so often?
My experience has been that the most vulnerable part is the propeller, I have never had a steel boat and only ever had folders which are made up from bronze and stainless steel in continuous contact. Saildrive legs add even more diverse metals to the mix. I suspect that a relatively cheap fixed prop. on a shaft drive might survive for quite a while without this protection but in the distant past I had one folder whose blades went a distinct pink with a dull sound when tapped after the undetected loss of a shaft anode. The next season the blades were soon rattling about on the pivot pins, I got oversize pins made but the rapid wear continued so the prop went for scrap. After that I always had two anodes on the shaft. So, even though we are rarely on shorepower, it would take a lot to convince me that anodes were unnecessary, they are cheap compared to propellers. It is worth having a walk around a boatyard in winter and having a good look at the condition of the propellers.
I have never (to my knowledge) had a corrosion problem with seacocks, on my current boat these are not even wired together and connected to an anode but they are well separated from each other and from any other metal parts.
Today I have a three blade bronze and stainless steel folder on a saildrive with a stainless rope cutter, there are all sorts of claims about isolation of the metals in the VP blurb but I am sufficiently sceptical to be obsessive about replacing the anodes on the prop. and cleaning the heavier ones on the leg. The speed with which the prop anodes degrade convinces me that something is going on.
On a slightly similar note ...
My perkins 4-108 has a completely isolated block. The instrumentation sensors, starter motor and alternator are all isolated from the battery system. A bit confusing when I tried to use the block as a ground for a meter lead once![]()
The propshaft and prop boss are all 316 stainless and the blades are plastic ( kiwi prop ) and I fitted one of those propshaft bushes with polypropylene spider to reduce vibration.
So in theory there is no reason to have straps across the spider to tie the propshaft to the block ( I have them there at the moment )
I have not see any evidence of corrosion on the prop and shaft but the iron keel appears to have been eaten like crazy previously. Even a couple of weeks a year in the water turns a 1/2 kg anode, mounted just forward and to stbd of the leading edge of the keel, to powder.
The anode is bonded to battery negative.
Anyone got any bright ideas on finding the stray currents?
Its a pity you have not started a new topic , However:
Your anode must be bonded with a low resistance connection to what ever it is intended to protect and be close to it.
If you have a fully isolated DC system there is no point in connecting the anode to the battery negative, in fact it is wrong to do so.
I dont think, "The instrumentation sensors, starter motor and alternator are all isolated from the battery system." is quite what you mean. Nothing would work. You mean, I assume, that they are isolated from the engine block!
You appear to have a major problem. I'd start by investigating just what is connected to what.
Do you have shore power..If so is that correctly connected esp with regards to the earth and does it include a galvanic isolator.
No obvious answers to the problem come to mind.
My first move would be to disconnect the bridging connection across the flexible coupling and put a meter across the coupling, with the engine running. If your engine is not separately earthed but is at some positive voltage it would seem it is earthing itself via the propshaft, completing the circuit via the keel..
