auditdata
This is the davit base from a friends yacht. It is less than a year old. The davits are rated at 60Kg each. The dingy is 52 kg and the motor 25kg. So the load is within spec. The top two bolds are welded in where as the other 4 are not. Presumably this was to aid mounting, as the angle would make insertion difficult when fitted. It surprises me that whatever load made the two top bolts fail it did not make the lower ones fail. The plate was flat originally. Is this a failure because of the weld?
Any advice and should the new one not be welded? Am I on the wrong track?
Pics below
Pics below
