LadyInBed
{Straight in with the 10 mm, no pilot.}
I wouldn't have drempt of doing that, what is the rational?
re read #20
Depends on the cordless. I'd back my 18v Li-Ion Makita to do it. The 12v NiMh, perhaps 50/50.
And...I just broke another cheap Chinese-made 3.5mm. No more of these pieces of crud, I'm only buying carbide ones henceforth. Or other recommendations...
When you grind your slots use a new wheel...
Very much this; the ~1mm discs are flexible and cutting can set up harmonic waves in them, sandwiching 2 or more together may cause them to interact and destruct.Cut off wheels ... personally I'd steer very clear of mounting multiple discs
I'm very glad to have asked the question because there's so much experience here. I've never had a pillar drill...along with router and lathe, it's something I'll one day fill a shed or on-board workshop with.
For now, I only have a new Draper 14.4v cordless drill/driver (a big advance on the hand-drill I was using) which certainly allows low turning speed. My initial under-estimate of the required hole diameter was 3mm, and with much patience, cooling-off time and a couple of broken inferior bits, I have now drilled through two sections of 10mm stainless.
So, my approach is really very humble. I'm basically trying to reproduce the spreader-end-caps which'll let me put the mast up without imminent prospect of it coming down again.
Apologies to contributors who were bored by my earlier description of this difficulty. The fact is, no-one makes the bit I need so I'm making it myself.
I determined that a 10mm dia stainless bolt with a square top, could be drilled through (4mm) to house the shroud, and I'll be grinding a slot longways up the bolt to enable the shroud to take its place in the hole without having to be fed through from its bulky end. So this thread might drift sideways to take in angle-grinding of stainless steel, too.
I'll photo the results...hopefully not a gory mess where my hands had been.![]()
