Who makes really tough HSS drill bits?
Greenheart
29 Dec 2010
Last month I asked a Scotsman working in a French DIY store, why some of the drill bits sold there were eight times the price of others. (This sounds like a joke; sorry, it isn't.)
He said the cheapies were Chinese and won't last; the costly ones were French and much better kit.
I readily paid the extra and I wish I'd bought them in all sizes. Today I bought 'superior' grades in three sizes here in the UK, but one has already snapped and the point of another is rounding-off.
Is there a manufacturer I should look for? I'm drilling 10mm-thick stainless steel. It's slow work and the ubiquitously-available Chinese bits are sadly inadequate.
Avocet
3 Jun 2001
Cumbria
I've always been fond of Dormer drill bits. I also have a set of cobalt steel bits (Screwfix's own) which are very good.
VicS
13 Jul 2002
Dormer is one of the names i was trying to remember. Presto is another good one IIRC
For drilling stainless steel you need cobalt steel bits.
25 Feb 2010
I've said it before and feel a bit sheepish doing so again, but I've found the drill sets from Lidl's to be the best I've ever had.
I bought a single drill for SS a sometime ago and it cost more and wasn't as good as a full set from Mr Lidl
Greenheart
29 Dec 2010
Thanks gents, the keyword seems to be cobalt...that's definitely one for my next trip to Ebay/Amazon. :)
I've heard that drilling-oil can help - both by cooling and by cleaning the bit's cutting edge. Any points of view on this?
prof pat pending
3 Jun 2013
Oxfordshire
You really want silicone carbide, but they are easy to chip
There's a knack to cutting stainless.
You mustn't let the material work harden as you cut it. Don't even centre punch to mark the start point.
Keep you drill speed low and your cut rate as high as you can, if you feel the drill going off sharpen it or get another, don't keep going.
....and use plenty of cutting fluid
Richard10002
17 Mar 2006
Manchester
I drilled some holes in my 4mm grab rail last year. The cheap HSS bits I had were useless. The Dormer drills I bought went through easily and remain sharp.
William_H
28 Jul 2003
West Australia
+1 Lots of pressure slow speed. I use engine oil. As soon as it starts to smoke you know it is all too hot or drill is too blunt. Stop. Large drills are easy to sharpen if you just look closely at the shape and angle of the cutting edges. olewill
Greenheart
29 Dec 2010
Thanks for these contributions. I just bought a little cordless drill, partly because it doesn't have the fixed, very high running speed of 240v drills I'd seen at similar prices.
What exactly is cutting fluid?
prof pat pending
3 Jun 2013
Oxfordshire
Depending on the grade I think you are going to stuggle to get through 10mm of stainless with a cordless.
Cutting fluid is usually a mix of soluble oil and water, it acts as a lubricant and a coolant
As mentioned above, engine oil will work, but I'd go for something a bit thinner
penfold
25 Aug 2003
On the Clyde
In this context cutting fluid is something like Rocol RTD liquid or compound, which is designed to improve finish and the life of cutting tools. Diluted cutting fluids aren't really appropriate for this job. Going through 10mm of stainless with a cordless drill will be a test of man, machine and drill bit, but a good quality bit and cutting fluid will get you there eventually, perhaps after a change of battery and an aching shoulder and arm.
DownWest
25 Dec 2007
S.W. France
A soluble oil that one mixes at around 3% with water. Aparently they have some very clever mixes for specific uses.
I never drill SS with a hand drill unless desperate. Slow speed and pressure are the key (as William H says) plus lots of coolant. I halved the lowest speed on my pillar drill (extra pulleys) to drill a load of 50mm holes in 6mm SS. It considerable extended the life of the hole saws from OMG to acceptabe.
The old 'suds' soluble oil was reputed to be the cause of testicular cancer with machine operators (leaning over lathes and stuffing rags in overall pockets) The stuff I use is a sort of bio product. But writ big on the container is 'Do not freeze', so I keep it in the house in the winter.
I find that decent HSS drills work fine, keep 'em sharp. The old Eclipse sharpener (best investment ever, but only found on e-bay now) is ace for honing new drills and slightly worn ones. The better drills from Brico Depot ( B & Q ) are good
Heckler
24 Feb 2003
I wanted bits to drill stainless. I did a search on ebay, dormer ones came up, a couole of quid each. I bought them, they work, slow speed, oil, and heavy pressure, knife thru butter!
They are designed for stainless with a "quicker" spiral and different angle on the cutting bit. They look like ordinary steel drill bits otherwise!
S
Heckler
24 Feb 2003
Just use a bit of engine oil, dont get fixated on cutting fluid! As someone else said, if it starts to smoke, stop and put a bit more on.
S
PS 55 years of maintenance experience!
trthebees
12 Feb 2003
west country/london
+1 for williamH and prof pat pending. I had to drill about 2,500 holes,10mm diameter, in 10mm SS making replacement drain covers for a hospital. Grade 304. Ok, I used a pillar drill. But the technique was moderately slow drill speed, probably about 300 rpm, loads of pressure and get on with it without hesitation. I used Rocol grease-like cutting paste....I can smell it now, lovely... and Dormer HSS drills. Straight in with the 10 mm, no pilot. I seem to recall I got about 30 holes before resistance or excess blueing or rear breakout indicated I needed to resharpen. It was like drilling cheese up to that point.
I know the above doesn't help when using a hand drill, and can't see your diameter in the posts, but I would be shoving hard, trying to maintain a steady slowish speed, and feeling what the drill is doing. Cutting paste is best, but if you've only a few holes, it can be expensive.
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
In my factory we have never used cobalt drills. We probably drill 10,000 holes of varying sizes in 304 and 316 stainless per year using HSS drills by Guhring, Trojan or Dormer (now Sandvik). Currently we are producing a batch of components for Morgan Cars requiring a 16mm hole (which has a 6mm pilot). Admittedly this is on a CNC lathe with loads of coolant.
Stainless steel is a poor conductor of heat and work hardens very easily if that heat is not removed.
As others have said, slow speed, loads of pressure, a fluid to remove the heat and stop the minute the going doesn't "feel right". If you don't stop, you will probably not be able to complete the hole without solid carbide.
sailorman
21 May 2003
Here or thertemp ashore
a 3m/m pilot hole first to remove the centre of the 10m/m hss bit, then slow & cold with lube & a sharp bit. i have never used cobalt
