MickToo
Yet again I've got knocking / clonking being experienced through the helm, which is almost certainly emanating from the "maintenance-free*" bottom bearing of the vertical shaft in the Whitlock Cobra steering pedestal.
I know that the steering arm is welded to the bottom of the vertical shaft and that has to be removed - however, given that the bevel gear quadrant at the top end is secured with stake-pins, my question is: 'is there any good reason not to drill and through bolt the steering arm to the shaft rather than renew the weld?'
Bolting all the way through will have the effect of clamping the bracket to the shaft and will have the added benefit of improved ease of removal / replacement when the offending bearing next fails, as surely it will.
* By "maintenance-free" I mean it's a sealed ball-race bearing and there's no facility to undertake any maintenance of it without major disassembly of the pedestal, currently requiring grinding off the welds on the steering arm and re-welding same on reassembly.
