BOBBIN
Yanmar 3HM35 raw water cooled engine shows steam/white smoke from exhaust increasing with revolutions.
Engine does not overheat.
Have replaced water pump, thermostats and water passing through anti syphon loop seems to be at moderate temperature with good flow.
Exhaust mixing elbow was removed about 12 months ago and carbon ground out of gas and water entrances.
Is it possible that this steam is caused by water/gasses not mixing properly? Or is there an alternative answer?
Although the engine starts first time, there is some evidence that the fuel supply to the injectors is not correct as injectors have been removed,checked and tested and replaced and black smoke is seen when putting engine under heavy sudden load. This disappears completely when revs are reduced.
Could these two problems be connected in some way? Is the steam not steam?
