R.Ems
Do you carry them? Have you used one? I can imagine a white flare, designed to illuminate an area brightly, could be very handy. Eg lost among rocks, MOB, etc.
No need to replace out of date pyrotechnics in the UK. They are quite safe if stored in the correct conditions.I’ve never had them so never used them and am questing whether or not to replace the usual coastal flares which are out of date this year.
My god what happened?Yeah. I used to keep old flares... One guess if i still do.
No the petrol container was NOT anywhere near.
They are lifed because the chemicals in the pyrotechnic degrade over time. They may work. They may not. They may burn incorrectly.No need to replace out of date pyrotechnics in the UK. They are quite safe if stored in the correct conditions.
Yes, I recall your original post. I was careful to state, 'They are quite safe if stored in the correct conditions', As I said on your original post I do not consider being sat on a liferaft in the cockpit locker somewhere on the Med with an ambient temperature of >30°C , I'd estimate 50°c in the locker, are not the correct conditions.Yeah. I used to keep old flares... One guess if i still do.
You failed to follow the manufacturer's instructions. Store in a cool dry place. In that cockpit locker between the liferaft and the lid in the heat of the Greek sunshine that are is going to get very, very, very hot. You were lucky that the quick reaction of other people saved your boat.
I would be interested if you ever measured the temperature in that area after the fire, just to see how hot it can get on a hot day in the Med. The place to store pyrotechnics in that climate was below the waterline next to the hull.
Interestingly, batteries could have also caused damage as their recommended temperature range is -14c to +50c.
True, but still usable. I am happy to carry pyrotechnics that are upto 10 years past their 'use by day' and have used some that were >20 years that worked. A bit like eating something a month out of date that had been kept correctly. Two years and that really is a risk.They are lifed because the chemicals in the pyrotechnic degrade over time. They may work. They may not. They may burn incorrectly.
Similarly, I don't eat out of date food just to see if I'm gonna get galloping gut rot.
I used to have a job that involved babysitting various categories of explosives and I totally trusted the maker.
Up to you......
Considering what they cost and the long expiry dates is it worth the risk?No need to replace out of date pyrotechnics in the UK. They are quite safe if stored in the correct conditions.
What complete nonsense from Pains Wessex - replacing a reusable plastic storage container does not make flares “sustainable”, and probably zero impact on plastic waste (can already buy flares without the pack, and have done for years). Adding a few extra years to the current 4-5 year state life, on the other hand, would hugely reduce waste and make a real difference to sustainability.I fully appreciate it is a marketing blurb but the video at the end of this article may be of interest.
Pains Wessex launches sustainable flare packs
