Whisker poles
Cloona
22 Aug 2006
i am looking for a couple of whisker poles for my jib and genoa - about 6 - 8 ft -
any suggested suppliers
EU regulations prevent the addition of personal criteria such as height and beardedness to job adverts for Eastern European migrant workers /forums/images/graemlins/grin.gif
just a suggestion compass24.com do a range of telescopic whisker poles. There is one that adjusts from 2m to 3.8m. a smaller one and two larger ones.
You fould find similar from other mail order chandleries and fittings makers
Seateach ... my Forespar extendable job does my 25ft sail job nicely ... your 6 - 8ft is actually quite short ... my WP is longer than that and was 135 quid over counter .... and a good bit of kit as well ...
Hundreds of pounds ???
These are just sticks we are talking about??
So tight I squeek when I walk.
[/ QUOTE ]Ah, but these are MARINE sticks with MARINE fittings on the end.
Stop complaining. If the label says medical it's even worse*. I just ordered 4 batterires for defibrillators on our ambulances 4.2AH lithium battery - use it up and throw it away - a snip at £110 a lump. /forums/images/graemlins/tongue.gif And you wondered why the NHS has financial problems?
As someone who's probably tighter than you - assuming that's possible, I'll accept just as tight if not, one solution for smaller boats is to go to a windsurfing club and find a discarded wind surfer mast. Cut to length, add a couple of snap shackles and a bit of epoxy - job done!
*Likwise aviation. I dread to thing what you'd pay for a £1 (sensible price) item for a flying doctor on a flying boat...
Blimey - we in competition then - I am well known NOT to spend ! People called out the Emergency Services when I bought the pole !
OK - another avenue - B&Q or DoItAll ..... telscopic paint roller pole .... dunno how long it'all last though.
Sanity at last ! - I love you all! /forums/images/graemlins/grin.gif
Got there in the end !! /forums/images/graemlins/smirk.gif
I have a B&Q extendable window cleaning pole with a home made end fitting. A hole through the handle and some 3mm codline is all I need to hole it in place against the mast. It works fine. Total cost <£20.00. Bugger SS boat fittings.
