Pinnacle
What does the panel recommend?
I'd use Lifecalk polysulfide. Fantastic stuff, though it stinks a bit.
Not good on teak thoughLifecalk polysulfide.
I've started to avoid using Sika in the yard and on my boat so much and have taken to using Arboseal Butyl Glazing Tape instead.
If you don't need the adhesive quality, ie, the fitting is bolted down, then the Butyl Glazing Tape provides a far better seal over time, much cleaner to use and when you come to remove it there's no mess.
Great stuff, but I cant find a chandlery that stocks it?
I have used Sikaflex 291 for every type of sealing job above and below the water for more than 20 years. I have never found a problem with it, except that it is quite expensive and doesn't last for ever once the tube has beeen opened. A couple of years ago I tried PU40 from Toolstation. It appears to be the same, or very similar, stuff and works just as well at about 40% of the cost.
Several people reported softening problems with the Sikaflex 291i version, possibly a faulty batch?
How about CT1? It has the added advantage of being able to cure underwater.
. FWIW, I've always just used PTFE tape on the threaded joints and have had no problems with them unscrewing themselves.
I'm very frugal with my PTFE - 3 turns is just right.The trick is to only wrap a maximum of three turns around the male thread. Then it won't unscrew. The problems come when there are ten or twelve turns of the PTFE.
