Which rope?
howardclark
16 Sep 2001
S. Wales
The halyard for our main is a pain. It’s 30m long, and either braid on a strand core or perhaps braid on braid. After hoisting correctly, give it 30 minutes and there is a sag in the sail which requires two people to go to the mast to retighten it. Then it doesn’t recur. In mild conditions this is no problem, but when you’re bouncing around in a blow then we could do without it!
Speaking to our sail maker he says this is a common problem with these types of rope where the core and sleeve are separate.
So if I change the halyard is the only option old fashioned 3 strand which isn’t as nice to handle?
Thanks for any advice
There is not a sailboat on the water which wouldn’t be better for the use of dyneema halyards. Ebay, Jimmy Green offcuts, it doesn't have to be grand prix racing stuff. Premium dyneema is better, but marginal for most boats. Just cruising dyneema is a quantum leap over polyester.
We changed our main halyard to dyneema -there are a number of different qualities/prices but we went based on a riggers advice -it’s much stiffer stuff than your old existing halyard so doesn’t coil so well and when freeing the halyard to drop main you have to watch it more as it runs through block to avoid it catching . Otherwise apart from price no real downside plus you also then have a spare main halyard for emergency use . A Winchard shackle attached are useful if buying a new halyard
Never happened with my wire halyard. Not really a recommendation since wire is now widely disliked, but when it came to replacing it there was a problem that the sheave might have worn a groove that wouldn’t accept Dyneema, so I replaced like for like.
A part of the beauty of dyneema is the DIY splicing. Wire is possible, but it’s a bitch to work with, plus dyneema is a fraction of the weight. But wire at least does not stretch much. Replacing sheaves with wire halyards, you should probably do that every few years. They definitely go a different shape from new🤣
Maybe should, but mine were still functional after 25 yr and well over a virtual circumnavigation. Not my problem now.
We have a cruising Dyneema main halyard and still have the same problem as the OP. I reckon it’s creep not stretch in our case, maybe because it’s cleated in a clutch?
I had a wire /braid rope main halyard for many years on my little trailer sailer. Came need to replace I could not find anyone to do as new splice wire to rope. Treied myself to do it but just not doable. I resorted to 4mm dyneema and spliced it to polyester braid tail for handling winching. Splice was a bit difficult /crude but seems to be OK where it goes in to mast at the bottom. Splicing thimble on at the top very easy.
So if I had to do it again I would use the 4mm dyneema but try to feed it inside the polyester braid tail right to the end.
I have had for some years a dyneema halyard for the jib. 6mm polyester cover which did stretch then 8mm polyester covered dyneema and that also stretches a little. I don't know how these fit in to "cruising dyneema" But yes dyneema is the way to go for OP. ol'will
