lw395
Only because I happened to be looking at this recently:
https://www.victronenergy.com/upload/documents/Datasheet-GEL-and-AGM-Batteries-EN.pdf
Which again, only mentions shorter life under float service.
Table 2: Design service life of Victron batteries under float service
Absolutely no mention of getting less cycles in a cyclic service life where the cycle rate is enough to kill the battery long before the 'float service life'.
Clearly, some boats are going to struggle to exercise a battery through say 500 cycles before the temperature-affected service life if the average temperature is as high as 40degC.
It can become an argument for having less batteries and working them harder.
Or sailing somewhere with a temperate climate....
