steved
Apologies in advance for another battery thread....
On the domestic side my boat is currently fitted with 4 x 6 volt 220 Ah Lifeline AGM batteries. I believe they are the original ones fitted to the boat when new some 12 years ago! They now appear to be losing their appetite to retain charge.
To replace like for like would cost in the region of £380 per battery, over £1500 total.
So what do my learned friends feel would be a suitable replacement at a more economical cost, I'm happy to continue with the 6 volt batteries as the wiring is set up for this.
I'm generally on shore power, but do like nights at anchor, the main draw would be from the fridge and freezer (2 separate under counter appliances). A 5kw generator is also fitted.
I have a Victron Multiplus Compact 12/2000/80 80Amp automatic battery charger with integral 2,000w inverter, would I have to change any of the charging settings if I changed to say wet batteries etc?
