penpal
I want to replace my pre filters for new Racor, which will be easier to replace the filter elements without having to prime the engines overtime I change the filters. I am not sure on the flow rate, I have twin 130 volvos with a cruise speed of 18 and a max of 22kn.
I Aldo have to make a choice between two singles or a dual filter, which allows for you to use one filter if the other blocks up for both engines.
My main reason for the change is you can change the filter from the top without having to take the entire filter off, glass bowlbas well, which is the case with the Lucas ones I have at present.
Any thoughts on this?
sent from my iPad
sent from my iPad
