stuartbaggs
Can anyone identify the lock in the attached photo? It looks really well kept.
Yup, cookham. Actually a really awkward lock to use!! Easiest lock in my mind is Hambledon, worst marlow. Sorry, thread drift..![]()
It certainly is Cookham, which for the record is very nearly the same size as Hambleden... about 20 foot longer at Hambleden and 4 inches wider!
Incidendally, being across the middle gates at Cookham Lock is considered VIP position... all that lovely wood to sit alongside instead of concrete.... and your lines will not come off the bollards if you put a turn on them!
Hambleden actually has a bottom-filling system (which may sound painful to some and no doubt appealing to others) but it does do a very convincing impression of a side-filling lock.
Double gates - looks like Cookham looking upstream.
Can I ask the obvious dumb question, that is, what is the purpose of that extra set of middle gates?
Surely it's not a staircase lock is it?
Cookham Lock was in fact rebuilt in the late 1950's (1957 IIRC)
It was electrically operated (as opposed to hydraulic) and had a middle set of gates to enable a shorter lock to be used to save time/water.
It was possible to use any 2 out of the 3 sets of gates, giving the choice of a small lock (head and middle), a medium sized lock (middle and tail), or a big lock (head and tail).
Three sets of gates is not a new idea, Boulters Lock had a middle set of gates until the rebuild in the early 80's when they were removed. If you look towards the road from the lock, you can work out where the middle gates were, by the layout of the steps.
Cookham Lock Office was like an old junction box, with a series of levers in it for operating the various gates and sluices, hence the much larger office building. The gates could also be operated from the front room of the lock house, this room was later converted into the infamous Lock Shop operated by the legendary Faye Andrews.
The electric system was replaced with hydraulics in the late 60's inline with the rest of the local locks.
The middle gates were kept for experimenting with new hydraulic operating systems. The middle pedestal is actually the early prototype for the Sulby system now in use at Boulters and below Windsor. Boaters were able to use the middle gates under public power and then only had to wind the other end. This often led to boats entering at both ends, with only the middle gates closed, they would then wind the set of gates closed that was behind them before spotting the other boat/s! (really funny to watch!!)
