Which 12v/mains Fridge
andyc
9 Jan 2004
I am in the unfortunate situation where I need to replace my rather large Norcold EV 461 fridge freezer as is runs but does not do cold any more.
Following lots of research ,I cannot find anything that fits well so have chosen the smaller Waeco CR140at 80cm high and will turn the top freezer door into a shelf for storage above which we do lack.The advantage of Waeco seems to be that it will run any voltage.My Norcold is 110V/12v DC and the Waeco seems to do both plus 240ac without mods.
Any other suggestions? Is waeco a good make or should I go Thetford or something else.?Thetford do something bigger but still leaves a gap fo 3 inches around.
vas
21 Jun 2011
Volos-Athens
+1 for waeco, unless I'm horribly wrong, it's considered one of the top brands.
I have one, performs much better than my vertifrigo one...
V.
David2452
6 Jun 2001
London & Fambridge
Whip it out and take it for a re gas, usually all that is needed if the compressor is still functioning OK and a relatively inexpensive fix.
abraxus
3 Aug 2004
Does it fail to get cold on both mains and DC?
I nearly replaced my Norcold because it was running but didn't always get cold. However, after disconnecting it from AC power and just letting it run on DC it's been fine.
andyc
9 Jan 2004
Ill try dcnext time as only ac been used.
abraxus
3 Aug 2004
In which case it's defintely worth trying. My Norcold is AC powered via a 240v to 110v transformer but according to the specs it needs 110v at a minumum of 59hz. UK AC is at 50hz and so effects the running of the fridge.
On 12v it's great and so I leave it on that permanently where it's powered by the batteries and/or charger.
