D
Deleted User YDKXO
I'm unsure what is at the the extreme stern end of that "spoiler" cavity. If that section is built to the same specs as the the rest of the hull, and the rearmost panel is structural, then great. But if that rearmost section is built more lightly, and the rearmost panel thin, then not so good.
To answer your question here is a pic of the 'spoiler' compartment of my boat
As you can see the longitudinal stringers in the engine bay do not stretch back into this compartment
Here are 2 pics of a SK9 installation in another Ferretti 630 in the spoiler compartment and as you can see the yard has moulded 2 longitudinal bearers into the space in order to mount the SK9, presumably using the existing lateral stringer for stiffness. There may be further stiffening under the gyro itself but I dont know
These pics were sent to me by Seakeeper Europe some months ago and they cant tell me whether or not this installation has proved robust in the long term
Yes under the master cabin berth would be a possible location but it would mean cutting a hole in the flybridge and saloon floors to get the gyro in and I really dont want to do that. Also we might want the gyro running overnight at anchor and having it under the bed would make it difficult to sleep
Actually the weight of the SK9 is 550kg. I did ask Ventura to ask Ferretti what their max design weight of jetski + tender was in order to compare it to the weight of the gyro and my existing tender. They came back and said that the max design weight of the jetski was only 160kg and didnt state a weight for the tender which I immediately questioned because of course a jetski normally weighs a lot more than that. They havent come back to me on that. My existing tender weighs about 140kg which with the gyro makes a total of 690kg. I was hoping that Ventura would say something like 350kg jetski + 350kg tender which would mean at least my tender + gyro would be within the design weight for that structure
