Where did you put your Navtex Aerial?
SlowlyButSurely
4 Jul 2003
Solent
I have just fitted a Clipper Easy Navtex. I was originally intending to mount the aerial on the pushpit but after I had mounted the display unit I switched it on to test it with the aerial down in the cabin and much to my surprise the signal strength was excellent. This is on a steel boat BTW. So I tried putting the aerial in various locations, ie, in a locker, on the pushpit, hauled it 10ft up on a halyard and the signal strength was completely unaffected so I settled on a position tucked away behind a panel in the wheelhouse next to a steel bulkhead.
Am I going to have a problem later on with this or is this normal with Navtex?
It's at MF frequencies rather than VHF, so height is not especially significant. Nearby interference and shielding may be; I'm somewhat surprised you got good signal inside a steel hull but it's all a bit of a black art.
Mine is inside the fibreglass cockpit coaming.
Can I ask what stations you are picking up reliably?
I have been playing with different antenna arrangements on an ICS receiver this winter, afloat in a Solent marina. It passes the time.
I have been using Niton, Corsen and Coruna as test stations. The standard passive antenna only gets Niton, a balun on a shroud gets Corsen and the balun plus long wire gets Coruna.
Hearing Coruna is good going :encouragement:
I have the current standard antenna (internal box receiver, fibreglass rod antenna, not the integrated shark's fin) and I only get Niton, which I get reliably (until last week, see other thread).
I did try connecting to a shroud (directly rather than via a balun; I'm not 100% sure what one of those is :) ) and picked up Niton poorly.
Did you have the receiver running yesterday by any chance?
I'm in the Solent too. I've got it set to pick up all stations. It's receiving Niton OK. There are messages from others but I'm not sure which ones. I will go down to the boat later and check.
I suspect atmospherics and surroundings (boats in the next berth) may be more of a factor than the position of your aerial.
In winter (pontoon berth in a marina) I get Cullercoats, Hamburg (with gash) and Ostend reliably, and that's about it.
In summer (swinging mooring on the Orwell - maybe half a mile from the pontoon berth) and I get Reykjavik, Split and Haifa all the time.
Aerial is a stubby 'mushroom' sitting on the pushpit.
Mine is in the saloon, fibre glass hull, good reception.
