seanfoster
I managed to remove all of the stanchions on my Dufour 1800, they are a sort of bayonet fitting, they sit in a plastic socket with a keyway, to remove you twist about 90 degrees and then pull out. Tha stantion has a pin welded to the base which allows them to lock.
Out of 6, 3 are ok 2 are slightly bent and one it badly bent.
I need to replace these but cant find anywhere on the web that looks like they do them, does anyone know where i might find them? (they have a single hole and are about 400mm high).
Alternatively does anyone know how they could be rescued?
