jimbaerselman
OK. Probably DC. One hand was touching a positive connected surface, the other was touching a negative connected surface.
Please note that 'earth' is irrelevant here. There is no natural potential difference between between 'mother earth' and a feed (terminal) unless the other feed has been deliberately connected to mother earth somewhere along the line . . . as in domestic AC installations.
In DC it is common for negative to be connected to the engine block . . . saves wires . . . and if your block is insulated from your 'leg', you need to ask the question, is the leg positive relative to the block/wet hull? (get that VA meter out!) and if so, why? Where's the connection?
