Murv
where most of the shaft is smooth and just the bottom is threaded, do you measure the smooth bit thickness or the threaded bit?
Sounds more like an M8, with a narrow shank. Normally an M8 bolt would measure 8mm at the plain shank, and marginally less at the thread. 7.6mm is 0.3" which is odd for an imperial size (not checked the old BSW/BSF dimensions).Superb, thank you.
Just to check mine isn't stepped then, I'm reading 7mm across the plain shank, but 7.6 across the threaded part, so it's an M7 bolt?
M7 is definitely an odd size, and the thread OD wouldn't be more than 7mm.
How are you measuring the diameter e.g. caliper or micrometer ?
Is this for the volvo penta 2003 with the ripped out thread on the water pump housing ?
Some VP pumps were Johnson which do use obscure non metric threads. If unsure use a normal M8 nut to see if the thread matches. A standard M8 will have 1.25mm pitch, with fine at 1mm pitch, and very fine at 0.75mm pitch.
To use a helicoil you will need space to get a drill in there to open the hole up, then be able and again have space to use a tap, the tap cuts a new thread then the helcoil screws into the new thread and your bolt then screws into the helicoil
Before helicoiling how about tapping the thread out to 10mm and fitting an M10 bolt. You may need to drill the existing thread to get to a tapping clearance. Buy a good quality bolt and use Locktite on it.
Got to be cheaper than helicoil.
Helicoils (or the various equivalents) do a good job. Problem, as stated, can be access. Depending on the material, it may not be necessary to drill the hole; the Helicoil tap has the same pitch (obviously!).
A rechargeable drill will sometimes be a space-economical method for turning the tap and will also be good for alignment. Use it on a low torque setting to avoid breakage. If access is really tight, you might get by with an open-ended spanner quarter turn at a time.
