EuanMcKenzie
As it was explained if you have a higher pitch which is the angle of the blade then the effective drive is increased at a fixed RPM.
Once you get nearer hull speed you'll get more "slippage" and you will waste more power trying to go a little bit faster.
By increasing the diameter and reducing the pitch I believe the engine will drive the boat slightly slower at tickover. By having a bigger prop I belive it has the ability to transfer more HP into the water so there will less slippage at speed. It should also be able to stop the boat better. Guess i'll still have to push in and out of gear when i want to go very slow as usual.
This has to be matched by maximum speed also hence if you look at the pitch on a gin palace it bears little resemblance to yacht prop
I am sure a greater expert will explain this more scientifically but i believe it will help a bit. I needed to change the prop anyway as the old engine is opposite handed to the new one. Worth checking on your boat I guess.
