sailorman
Fit a PRM box then no brake is reqI like the Nanni and they do a nice 62hp. The one I'm looking at though is a Mermaid MP58, it's £5k supplied and £1.5 fitting plus my new prop, whatever that turns out to be. The bruntons gets more complicated when you factor in £1.5k for the required shaft brake.
I'm guessing my gearbox ratio, it has 3.1 stamped in front of the serial number, but that could be something else, but it does make sense of the huge prop. Kiwi are now doing the K4 and that's a four blade prop which doesn't need a shaft break. All in all the Kiwi gives most of the benefits of the Bruntons and is £4.5k cheaper as a package. New engine, new feathering prop and all the benefits therein for £8k is a highly attractive proposition if, and only if, the 58hp is big enough. Some of the panel's views though cast doubt. I suspect that the engine I have has masses of torque in the low revs but the proposed new one will not deliver its big dollop of torque until much later in the revs.
http://boatdiesel.com/Forums/index.cfm?CFAPP=9&Forum_ID=159
http://boatdiesel.com/Engines/Thornycroft/Thornycroft.cfm
