Whats going on with this boom and spray hood combo?
salad
1 Jun 2019
I'm new at all this, so maybe it's totally normal to have this configuration, but to me it looks like the boom cannot pass the spray hood. Would this not make it difficult to tack or gybe? Is the topping lift just super slack perhaps?
Open to being educated. It's a 2002 Hanse, if it matters.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Yes, maybe boom lowered so that the zip can be reached and a preventer used to retain the boom to port side so as not to swing around...
salad
1 Jun 2019
I knew there would be an explanation, thank you.
Until we find a boat I'm stuck with eSail and books, which are all very good to be fair, but reading on here has provided just as much knowledge and you're all so helpful!
ashtead
17 Jun 2008
Surrey and Gosport UK
It’s caused by too much winching in on the German mainsheet system or whichever mainsheet this model has or the vang also known as a strut or kicking strap by some. It must have been pulled in a lot to hit top of sprayhood maybe to assist in zipping stack pack up or it could be camera angle. The more normal issue with low boom is when you put up the cockpit tent or Bimini . While we have a Moody ,I suspect the topping lift is hardly touched on a Hanse as the boom is held up by the vang but clearly this one might be missing its vang strut. These struts are supplied with the boom by Selden in case you wish to research further. Other boom and strut makers exist though.
salad
1 Jun 2019
Could someone tell me what the metal bar is that crosses the cockpit please? I couldn't consider the boat due to this as I think it's too much of a hazard for kids (and me tbh).
Mainsheet traveller?
ashtead
17 Jun 2008
Yes -nightmare and also has a rope attached for catching them. Look for a boat with a traveller which is what it’s called in front of that sprayhood(as per Say older bavaria but it’s further away to let off for helm) or on stern (as per the westerly centaur ) which is close by but the rope can still catch neck of unwary etc .Ideally you have what is called German mainsheet system with a rope running to either side to pull in the boom and no traveller etc but that is more modern idea than say a 2002 Hanse. I think a boat with wheel steering far easier for a family yacht-try looking at a small Hunter Legend -plenty of space for kids etc . Get a bilge keel version and you can park it on the beach as well.
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
Yes it is a mainsheet traveller. Not a great location - mine is across the bridgedeck by the companion way so still needs a bit of care when tacking or gybing. You can get nainsheet systems that have the traveller on the coach roof which is much safer, particularly with kids in the cockpit.
salad
1 Jun 2019
Thanks gents. Bilge keel has been on the radar as the occassional overnight on/near a beach might be rather fun. Lots of nice sandy beaches up in Scotland too. So few to choose from and the ones which hang around tend to have less desirable traits, as you'd expect.
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Plug ugly sprayhood! Put it down to go sailing: better visibility, less windage, and a prettier boat!
DJE
21 Jun 2004
Fareham
www.casl.uk.com
Yes it's the mainsheet traveller. Vital for good control of leach tension upwind.
Sailing boats have all kinds of ropes and moving parts that can be dangerous particularly to children.
Usually the more convenient arrangements sacrifice a bit of sailing performance for improved comfort in harbour.
scottie
14 Nov 2001
scotland
If you look on the cockpit floor you will see an eye that the main sheet can be fastened to instead which allows you have a less complicated system with the advantages of the traveller
another option is to put a traveller in top of the cabin roof
each system has its advantages and disadvantages
a lot depends on how well you wish to control the mainsheet
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
On my elderly offshore racer the mainsheet track divides the helmsbody’s cockpit (very comfy bench, perfect view ahead, but she will insist on throwing the top of a wave at you from time to time) from the gorillas’ cockpit (perfectly sheltered, but you do have to wake up and do something with a #65 winch when we tack, and more when we gybe).
