What type of rope
PabloPicasso
12 Feb 2010
What type of rope is best for fore and aft mooring lines? I'm intending to shackle through eye thimbles to the chain riser. Is that the best way?
john_morris_uk
3 Jul 2002
At sea somewhere.
Cheep polypropylene, slightly over sized diameter
Will have ample strength & will wear just the same as anything else if it goes over a sharp edge
The trouble is that I've seen too many bits of polyprop line crumble to dust after a good dose of UV. It starts to look a bit hairy and there it is 'wedi mynd'. (It's Welsh for 'gone' just to confuse you.)
rob2
23 Aug 2005
Hampshire UK
I used to be on a fore and aft mooring. There were two strops each end and a pick-up line between the buoys. The contractor used a heavy polypropylene rope which lasted for years. There are two forms of PP rope, one is "split film" which is weak and short-lived, breaking down quickly in UV and prone to rapid wear. The other, which I believe is called "staple", is properly made rope which is much harder and stronger.
Although I use nylon lines to my mid-river pontoon, I would probably chose polyester for a fore and aft mooring between buoys. The rope remains pliable when wet (unlike nylon) and the extra stretch of nylon ids not needed with the chain catenary beneath the buoys.
Rob.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Same here, but not cheap blue. I use the orange, I believe that it is more resistant to uv.
They have been in use for about seven years, I took them off this winter and inspected them, all in surprisingly good nick.
