What to do with useless ball fender ?
Refueler
13 Sep 2008
Far away from hooray henrys
The thread : How do I deflate this fender? ... has me thinking about the useless ball fender I have ... which has this ridiculous double valve.
The threaded part in the ball is faulty and air escapes via the joint of the outer to inner skin whatever I do ... that's IF I can get air past the stupid valve !
I'm wondering if I can fill the fender with something else - ie foam or similar ?
Shame to waste such a ball fender - but if it cannot stay 'inflated' its no use to anyone.
Ideas (I've already considered binning it !) ?????
ducked
6 Oct 2024
Tainan, Taiwan
One of those similarly useless tyre inflation kits?
And/or, if you can get it to hold air with some kind of sealant, you could perhaps inject an appropriate amount of diluted grape juice with bakers yeast.
Thought of this as a self-inflating tyre trick but never did anything about it. Need trial and error to get the amounts right for the volume, and overinflation error could be dangerous.
Refueler
13 Sep 2008
I bought new valves for it .... still same ... then found the two skins were leaking around the valve fitting.
I have had a hard look at this valve design and really cannot see the logic of it ... what's wrong with the old needle valve most use ??
I have liquid PVC specially for repairing dinghys ... I may try some to seal the skins ...
