What the most effective product
Can someone please explain how a passive nozzle, spinning by the water flow from an average engine that produces ~100 bar (1450 psi) without any added energy can more than double the pressure?
I would not say I am an expert... but on my karcher the spinning nozzle has more power, it will cut grooves in wood and scour paving slabs etching the surface of concrete slabs.
a quick google says " Rotating nozzles
use centrifugal force to produce a strong impact and a spray pattern. ... The nozzle rotates a powerful, zero degree spray pattern in a circular motion to break down tough dirt and grime. By spinning the discharge water, the spray adds additional scrubbing ability to the cleaning process" .
I use oxalic acid , buy it on eBay cheap as chips in granules mix with water have look on YouTube for amount to use and put in pump up sprayer , works great , recently did boat that hadn’t been cleaned in 10 years left under conifer trees, I pressure washed it even tried jif but nothing would get staining out of the none slip and the sides wasted so much time scrubbing then I remember that I still have some oxalic granules , I mixed up some oxalic acid and it melted the marks off before my eyes not even any need to scrub and quick hoze off , oxalic acaid is the main ingredient in lots of the expensive starbrite products
Would Cilit Bang or Brintons patio cleaner damage synthetic teak as I am worried that my relatively new aft deck could get stained by these products perhaps
We use patio magic on Flexiteak (mindful other makes might be different though) and have done so for some years without obvious adverse effects. If you are worried maybe a call to the aft deck “teak” supplier or try on a sample ? You can lightly sand Flexiteak if black marks or scratches at say a boarding gate point
Oxalic acid is great for stains but pretty useless for general dirt.
