What surface filler
Frank mellin
17 Dec 2016
Having stripped back the planking above water line on my folkboat all of which is in excellent condition, have applied coat of primer which shows up lots of small blemishes
I need to fill all and then sand back to smooth finish before repriming.
Can anyone suggest an easy sanding one part filler that will give a fine fill.
Hi Frank, If you really need a single pack then I have found Epifanes Combi to be adequate. However, my favourite fine surface filler is one made by Bonda called FEW which stands for Fine, Elastic, White. It is a two pack filler. It normally comes with a red catalyst so you can ensure a really good mix but if you need to use it between white top coats you can also get a white catalyst. It sands beautifully and the surface is so smooth that it can even be used between gloss top coats without showing. It is a polyester filler and seems to stay put. I've no connection with them, just like the product.
After trying micro ballons and another lightweight filler powder and epoxy, I went back to talcum and polyester. The epoxy dragged, didn't go off for many hours, but the talc based was fine and smooth and easier to apply, went off in >30mins.
I though it was just me and epoxy, but I tried it many times with great care. Seems to me you need too much microballoons before the mix is stiff enough to apply without sagging.
I have badly opened seams due to the heatwave and boat on the trailer, Seaware sold me Epiphanes combi, knife applied for above WL. Haven't tried it yet.
