Cybers
Hello, need advice on a battery for my boat? It has a 2 cylinder 20hp Volvo inboard engine. Will a standard car battery be good enough?
If it is a dedicated engine start battery then anything recommended for a small diesel engine car will do that fits the space you have. Engine start batteries have a really easy time in a boat, provided you have a good charging system to give an instant charge when you have used it. If you have an alternator and you run the engine enough to get it up to working temperature each time the battery will last for years.
The problems start if you want to use the same battery for powering your other electrical requirements. Then you need to consider having a separate house bank and a split charging system that always ensures the start battery is charged first and wire the boat so that all the services come from the house battery. Sensible also to have some way of using the house battery to start the engine in an emergency.
Thanks to all, very good info. The original battery was a old car battery that didn't work..... Which is why I was scratching my head a lot, the only electrics I will be running are nav/stern lights, VHF, gps and fishfinder.
In what way did not work ?
If you will be running much load without the engine running ( like a sailing boat does running nav lights etc all night) then I agree a Leisure battery may be a better choice
Dont forget LED lights can reduce your battery drain enormously
Never use a leisure battery as a main engine battery, the reason people use leisure batteries is for leisure items.
Leisure batteries are not designed for the large starting currents required by a starter motor, which effectively short circuits the battery, they are designed for low drain applications. It is a common misconception thet they are the same as a car battery, they're not, stick to a car battery.
If you want a one battery system then opt for a traction or semi traction battery, they are designed to cope with the high current of a starter motor and will cope with small discharges, and suffer heavy or total discharges without damage.
These are an example of the semi-traction batteries I refer to.
We have the same issues with 4X4's where electric winches are used, often the faster winches use very high powered electric motors, and we also use at least a semi traction battery to replace the original battery, in most cases its a traction battery.
I think you may be confused with terminology, its all to do with cycle, a conventional car battery has a medium duty cycle, a semi-traction has a deeper cycle, and traction batteries have deep cycles.
