Daydream believer
It will probably be hanked on. You really do not want to be mucking around on the foredeck hanking on a storm jib and then raising it. You will have listened to the forecast and decide that in the fullness of time you will need the storm jib - ideally that is the time to hank on. But it will be too early to hoist. Ask the sailmaker about a bag in which you can keep the sail, hanked on, sheets attached - such that you can hoist and set it from the cockpit (maybe the bag secured closed with Velcro and tied down to the deck, somehow.).
That all sounds very well but I would like to hear from those with inner forstays that are close to the main forstay how they get on tacking the genoa ( furled or part furled) in the times leading up to when they decide to stop using the genoa and resort to the storm jib. I can see the genoa creating a lot of friction around the wire & unless the crew go through a tiring process of furling & un furling it It will catch the wind & also some water between the 2 stays.
As it has been said it will be awkward to set the inner stay & hank on the jib in heavy weather.
In my opinion the ideal option for a cross channel & coastal sailor would be to have a smaller jib to be hoisted before departure when boisterous conditions are expected. My Hanse has a self tacking jib which I can carry up to F8 Ok without ever furling it& in practice , because the current one is a laminate, I rarely feel the need for the genoa unless the wind is very light. I appreciate that would not apply on many designs of yacht but having a smaller option for ,say, F5 & up would not only save furling the genoa but would give a much wider wind range if going on a longer coastal trip & be a faster sail as it would set better , not being furled
For the very few times an inner stay is required the hassle of stowing it against the mast or outer shroud & possibility of kinking the wire should also be considered. Perhaps a dynema one is possible!!
