What size rope for Lazy Jacks
snowleopard
Oxford
Would 6mm do? or would it need to be lighter?
Also can you buy covered blocks? or is there no need?
Rob
6mm should be fine, that's what I use on my 500 sq ft main. With a smaller main you might go down to 5mm. Anything smaller is string.
Forget fancy blocks, just use a stainless ring. Cheaper, no chafe. The only place you need a block is where it joins the mast.
BAtoo
1 Mar 2004
East Coast
""The only place you need a block is where it joins the mast.""
On the KISS principle i have just got rid of my mast blocks and the line t now just runs through a simple saddle eye!
5 or 6mm rope will be fine.
Stork_III
6 Aug 2002
Here and There
Use 6mm with sewn eyes, even less "no chafe".
snooks
12 Jun 2001
Me: Surrey Pixie: Solent
www.grahamsnook.com
Barton make a kit it's only £320!
The key I've found to lazy jacks and a good system is the mast track end. if your sail slides a as close to friction free as possible (and to have a fully battened main) then you can cast off the halyard and watch it fall down neatly.
If you want to go with covered block you can, but a previous owner of Pixie has just used the nylon/plastic eyes that are spliced into rope....but instead of splicing the rings he has sewn the rope together. Job done!
Should save you about £300!
theguerns
16 Jan 2009
rope size
I have just made new for our Colvic Watson 32 in 6mm three strand and used S/S thimbles. I use 3 strand so I can splice in the thimbles total cost €120 Time taken plus fitting 2.5 hrs
emsworthy
15 Jul 2009
Emsworth'ish
KISS!
Am I missing something here?
One of the most effective lazy jack systems I've seen has simple loops about 30mm long formed by bowlines at the various junctions of the lines, this is on a HR36 that has done at least one Atlantic circuit in its current ownership with no chafe or wear to sail or lines and not a mention of blocks, splicing or eyes sewn in. :cool:
26 Dec 2009
Tottington Hall, near Bury, in the Duchy of Lancas
Yes, the KISS approach works very well. If one is at all uncertain, then just use round nylon/plastic rings ( about 50p each ), with the line sewn or tied in and the short end neatly bound with self-amalgamating tape. That's as done on a Rival 34 nearly a decade ago, and still going strong.
Having s/s eyes, small expensive sheave blocks, covers, et all just adds to the weight and expense, and adds chafe to the mainsail They don't add to the functionality....
:cool:
Stork_III
6 Aug 2002
Here and There
Tied bowlines work just as well, but whipped or sewn soft eye just neater.
CAPTAIN FANTASTIC
15 Jul 2009
Bristol Channel
Just like mine:)
snowleopard
Oxford
Some have their lazyjacks pretty well static once they have adjusted the tension at the start of the season. If you do that there will be little chafe as the ropes don't move over each other.
Some arrange them so they can be pulled forwards to the mast so they don't snag when hoisting the main. If you do it that way you'll need to reduce friction and chafe.
