What size pliers for 3YM30 throttle/regulator cable c-clip?
farmer.leo
8 Oct 2011
There are evidently different size pliers for c-clips. Does anyone know the size pliers made to detach/attach the c-clip to the Yanmar 3YM30 regulator/throttle cable?
garymalmgren
28 Jan 2017
Try and get hold of a set of these.
I have dedicated cir-clip pliers as well as these and these are great. You get straight opening and closing as well as 90 degree bend opening and closing.
Japanese quality too.
gary
TradeTools
William_H
28 Jul 2003
West Australia
The important part is to be able to get the tip of the circlip pliers into the holes in the circlip. Looks fairly small to me.
Meanwhile I love circlip pliers for use when splicing 3 strand rope. Shove the points in while together. Then squeeze handles to open up a gap for threading in the rope strand. ol'will
Refueler
13 Sep 2008
Far away from hooray henrys
Unlike a spanner that needs to fit a nut exactly - Cireclip Pliers just rely on the pins being able to fit into the C clips holes. It makes no odds if pins are smaller diameter ...
But one factor that no-one else has mentioned ... if you have pliers that have the pins too far apart - then the pin is at bad angle in the C clip and it can 'spring' off the pliers pins ... done it - got the T shirt and the job of replacing the lost clip !!
